11-19-2025
01:19 PM
09:36 AM
Driver for Image Formula RS40 on Mac Tahoe 26
I am running Mac OS Tahoe 26.1 and cannot use my scanner after the update. When I try to use it I get this error message:
“CaptureOnTouch” is damaged and can’t be opened.
Does anyone know if there is a work around or updated driver that can patch this problem.
11-24-2025 05:03 PM
I called the support line at 800-423-2366 and they got it to work. I had too many apps opened so there wasn't enough memory for the driver to install. Try force quitting everything then install the app and the driver. If that doesn't work I called the above 800 number and only waited about 5 minutes to get support.
11-20-2025 08:15 PM
I have the same problem. Just bought it and wish I knew Canon doesn't know how to fix it???!!!
11-21-2025 03:12 PM - edited 11-21-2025 03:12 PM
For this type of issue, please call our Imaging Solutions Group at 1-800-423-2366, 8:00 a.m. to 8:00 p.m. EST, Monday - Friday (excluding holidays). I understand that the forum may be your preferred method of communication; however, these steps need to be provided by phone with a technician assisting you through it.
Following these steps will get you to the appropriate technician faster.
We look forward to hearing from you.
11-24-2025 05:03 PM
12-19-2025 01:37 PM
This worked perfectly!!! I closed out everything and then re-installed the driver and it works great! Thank you for this solution!
