12-27-2022
08:07 PM
09:00 AM
Hello Everyone,
I have only used this scanner 8-10 times. I tried to use it to scanner some important documents today but it simply won't scan. I placed the document into the feed and there is not a single sound or internal movement within the scanner.
I called the service line and they said they do not know what the issue is with the scanner and that I am basically out of luck since it only 3 months out of the 1 year warranty!!! Then they offered me a refurbished one for $150? To say the least I was disappointed and angry.
Hopefully someone can help me out ? I knew I should have just stuck with the snap scan models with Fujitsu.
12-29-2022 10:33 AM
What version of Windows or MacOS are you running?
01-21-2023 03:28 PM
I have the same problem since summer. I have MacOs Monterey. It's so annoying that i can't use the device since august.
01-21-2023 03:47 PM
01-21-2023 04:33 PM
and also. I updated to IOS Ventura 13.1 and Downloaded the canon drives and app update and still the same problem.I wasted so much money for this scanner and i used it only one time. This is not okay!
01-23-2023 01:03 PM
It is recommended that you call our Enterprise & Desktop Solutions Divisions at 1-800-423-2366 Monday-Friday 9:00 am to 8:00 pm ET, excluding holidays.
We apologize for any inconvenience this may cause; however, the steps needed to resolve the issue at this point, need to be provided by phone with a technician assisting you through them.
We look forward to hearing from you.
03/02/2023: New Firmware Updates Are Available:
EOS R7 - Version 1.3.0EOS R10 - Version 1.3.02/07/2023: New product announcements!
