imageFORMULA DR-M160II Error MacOS Sonoma when starting CaptureOnTouch
fs051268
I am getting this error after updating to MacOS 14
Screenshot 2023-10-06 at 08.40.58.pngScreenshot 2023-10-06 at 08.40.58.png Screenshot 2023-10-06 at 08.40.09.pngScreenshot 2023-10-06 at 08.40.09.png Screenshot 2023-10-06 at 08.43.03.pngScreenshot 2023-10-06 at 08.43.03.png
When reinstalling I got this:
Screenshot 2023-10-06 at 08.46.17.pngScreenshot 2023-10-06 at 08.46.17.pngScreenshot 2023-10-06 at 08.46.32.pngScreenshot 2023-10-06 at 08.46.32.png
Does anyone know what I could do?
Currently there are no drivers for MacOS Sonoma but as a work around please delete the scanner from the Printers and Scanner tab and then disconnect the scanner. Once that is done restart you computer and once everything is up and running click HERE to open the support page for our scanner.
You will want to change the operating system from Sonoma to Ventura so you can download and reisntall the driver and CaptureOnTouch software. Please make sure to leave the scanner disconnected when reinstalling the driver and software.
After both files are reinstalled, reconnect the scanner and open CaptureOnTouch to try and scan.
3 REPLIES 3
Arthur
Moderator
Moderator
Hello!
So that the Community can help you better, we will need to know more information.
What is the exact model you're using (it's usually on the top or front of the unit)?
Any other details you'd like to give will only help the Community better understand your issue.
If you're in the United States, and this is an urgent support need, please click HERE to visit your My Canon Account to discover your personalized support options.
If you're outside the USA, please click HERE to find support options in your country.
Thanks and have a great day!
fs051268
The device is: DR-M160II
The error happens when I start the CaptureOnTouch application.
