imageFORMULA DR-G2090/CaptureOnTouch: passive pop-up “Process has been completed” appears repeatedly
Anodos
Hi guys,
When I scan a book with my flatbed scanner Canon “Unit 201” in combination with CaptureOnTouch, the annoying passive pop-up “Process has been completed” considerably hinders a smooth process. As soon as I have scanned a double page of a book, I open the next page (while the image sensor is still retracting) and reposition the book. For a new scan of the book (resp. the spread) that is now ready, all I have to do is press the return key. But: Every time after a scan has been carried out, the annoying passive pop-up “Process has been completed” appears for several seconds in the bottom right-hand corner of the screen:
As long as this pop-up appears, pressing the Return key will not trigger a new scan. Only when the pop-up has disappeared can a new scan be triggered by pressing the Return key. And this is very annoying because the pop-up appears for an unusually long time, making it impossible to work smoothly.
Is it possible to set the duration of this pop-up somewhere? Such a possibility could also be hidden in the registry or in the depths of some *.xml file. I would just need to know it in order to be able to edit it accordingly. Thank you very much.
Anodos
Flatbed Scanner Unit 201
Win 10 Pro (22H2)
CaptureOnTouch Pro 5.1.1523
DR-G2000Series Driver 1.2.12007.3001SP3
2 REPLIES 2
ArthurJ
Based on this type of issue, I recommend reaching out to Canon support at 1-800-423-2366, Monday - Friday, 9:00 AM - 8:00 PM EST (excluding holidays).
We look forward to hearing from you.
Anodos
Hi ArthurJ,
Thank you very much for your advice.
As I live in Germany, I assume that the telephone number you mentioned would not apply to me. What would be the equivalent for Germany?
Basically, I had placed more hope in the forum because I can “illustrate” my request here. I am afraid that the Canon support staff would not really understand the problem if I only told them verbally. Would you also have an e-mail address for Canon support in Germany?
And: Wouldn’t it be easiest to forward the problem described here to the specialist department so that one of them could answer here (which might also help others who have the same problem)?
Anodos
