imageFORMULA DR-S150 Screen only displays Canon logo
Ivobas
I have 1 problem with my Canon image formula DR-s 150 camera. When I turn it on, the image on the sc
3 REPLIES 3
Moderator
Moderator
Thanks for joining the conversation, lvobas!
So that the Community can help you better, please reply with a description of the issue that you're facing.  It looks like you tried to put that in the subject line and you ran out of room and we moved that text to the body of the post. Any details you can provide will help the Community better understand your issue!
Thanks and have a great day!
Ivobas
hello, I have 1 problem with my canon image formula Dr-s150, when I turn it on, the screen only displays canon
Plaise help me🙏🙏
This is usually an indication of a corrupt or damaged boot ROM.  Did the device experience any power related anomalies.  Surge, dip, etc?  Winter storms.
You can try unplugging the device, then pressing and holding the power button for 30 sec.  Then reconnect to power and attempt to start it again.  If that doesn't help, the device will likely require service.
The DR-150 has a 3 yr warranty, and e-CarePak options are also available.  You can visit MyCanon to see what support options are available.
MyCanon
Friends and Family
