canon R40 scanner CaptureOnTouch Program Issues
TurtleMAN
When using the CaptureOnTouch program to read images from files, the message "The operation cannot continue. Please check the output settings. [Error: 8FFC020A]" will be printed.
This problem occurred when I imported a jpg image file from a file, but it does not occur when only a few jpg images print an error message and import another jpg image file, so it is not easy to know the cause of the problem.
The document scanner I use is R40, and I installed the TWAIN driver and used the optional OCR module for CaptureOnTouch V5 Pro and CaptureOnTouch V5 Pro. I wondered if it was a problem with the utility program, so I deleted and reinstalled the same problem, and I completely removed the existing utility program and installed the CaptureOnTouch V5 Pro V5.3.1024.1128 and the CaptureOnTouch Pro Optional OCR module provided on the newly released DR-S350NW product page, and tried again, but it did not solve it. I am using x64 operating system.
[Error: 8FFC020A] would appreciate it if you could let me know what kind of problem situation it is in or how I can solve that problem.
My native language is not English, so I used a translator. I hope my difficulties are conveyed well.
I really need help.
1 REPLY 1
Moderator
Moderator
Thanks for joining the conversation, TurtleMAN!
So that the Community can help you better, we need to know exactly which operating system is running on your computer (i.e. Windows or macOS, and which version thereof). That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
Friends and Family
