CanoScan 8800F takes over 16 minutes to scan 4 35mm slides
DBob
I am scanning 35mm slides using a CanoScan 8800F and VueScan 9.8.46.10 on a M2 Mac mini 15.5.  The CanoScan uses a 4 slide mask for scanning.  I placed 4 slides in the respective slots and pressed "Scan".  VueScan took 16.5 min. to scan the 4 slides.  Is it possible to scan a single slide in less time?  How?
1 REPLY 1
I suggest you contact Hamrick Software for configuration options.  🙂
