04-17-2024
11:14 PM
11:48 PM
StevenMOD
I see how to set it up when there is a wifi connection. Will the app work for a single camera (XF605 in my case) using the camcorder's wifi direct access point connection?
04-20-2024 03:52 AM
Hi NickMDal,
Unfortunately the App is not compatible with the Camera Access Point mode WiFi connection.
04-19-2024 07:29 PM
Hi NickMDal,
Are you asking about the Browser Remote function? That function can only be done through a router network, so it wouldn't be available when the camera is the access point. For Browser Remote to work you would connect the camera to a router with either wi-fi or an ethernet cable, have an IP address assigned to the camera, and the you can access the Browser Remote by pinging the camera's IP address on a device connected to the same network.
04-19-2024 11:06 PM
Hi. No since Browser Remote does not work on a tablet (see other recent thread). I am referring to the Canon Multi-Camera Control App.
04-20-2024 03:52 AM
Hi NickMDal,
04-21-2024 12:57 AM
Thanks for answering, though bummer! I hope the issues with Camera Remote in a tablet are solved soon. Can only use a tiny cell phone screen which makes touch focus difficult.0
