08-13-2025 08:12 PM
Easy to do with the photo side settings. That doesn't seem to save the video settings though. Every time I update firmware it wipes all my video settings and I have to go back through and reset everything one setting at a time. There must be a way to save the settings for the video side right?
08-14-2025 04:39 AM
Yes, there is. In video mode, go into the "wrench" menu, and it's the 4th option down - Transfer Menu/CP.
It does seem that you have to do both (photo and video); because the two sides of the camera really are 2 different operating systems, with different ways of doing things. Your video settings will be saved as a folder called "PRIVATE", and your photo settings will be saved as a file called "CAMSET01.CSD". Looks like it saves to whichever card is selected for recording photos.
08-14-2025 04:39 AM
08-14-2025 12:32 PM
I knew it had to be in there somewhere! Thanks so much, I will try it out. Many thanks!
08-14-2025 02:51 PM
No problem! If this helped, you could mark it as a solution, so others can find it. Cheers!
