08-03-2024
10:56 AM
10:58 AM
Just purchased a Canon 200 C with a PL mount. Does anyone know of an adapter to convert from PL to EF mounts or other mounts? Thanks
08-03-2024 11:39 AM - edited 08-03-2024 12:41 PM
This must be a rather old C200 series camera. ARRI made the PL mount, but it was a long time ago and everything went to EF until the C70, R5 C and others.
You are going to be limited and will have to stick with positive lock lenses. I'm not aware of any way to use EF lenses on a PL mount body. PL mount has a 52mm flange distance, EF has 44mm.
08-03-2024 12:32 PM
Shadowsports,
Thanks for getting back to my question. Does look like I will have to stick with the PL lenses.
08-03-2024 12:42 PM
Yes. I did more research and updated my reply.
08-04-2024 03:45 AM
The PL mount has a very long flange distance -- 52mm -- so in general adapting any other lenses to it is basically impossible. EF lenses, for example, need to be 44mm from the sensor, so it's not possible to make an adapter for that.
However, Canon's page for the C200 mentions a "Lens Mount Change Service". The link, unfortunately, is broken, so maybe it's defunct. But it might be that there's a glimmer of hope.
https://www.canon.co.uk/video-cameras/eos-c200/
If you want to know more about lens mount compatibility, I wrote an article about tthat: https://moonblink.info/MudLake/gear/lenses
08-04-2024 03:47 AM
BTW, the PL mount is very much alive and well. Lots of cameras have it as an option, and lots of cine lenses come in PL mount as an option. However if you're looking for autofocus lenses, then PL is not the way to go.
08-04-2024 10:40 AM
Thanks for the link. Pretty informative for this rookie.
08-04-2024 10:41 AM
Not realy looking for autofocus
08-04-2024 10:49 AM - edited 08-04-2024 10:52 AM
You can convert it. Information is on our site HERE.
Go down to the section called "Service Upgrades."
