01-07-2026
03:09 PM
09:20 AM
Hi all.
My name is Michael, and I am new to this forum.
My friend noticed, and I could confirm the same with the same combination
that there seems to be a bug with
- Canon Cinema EOS C50 Camera, Firmware 1.0.0.1 and 1.0.1.1
- Canon RF 600mm F4L IS USM Lens, Firmware 1.0.6
in picture mode when trying to shoot in High+ (H+):
As soon as you push the shutter button with that combination and in that specific mode, the camera "freezes".
When you remove the battery and put it back again, the camera can be used again as normal.
Are there other Canon Cinema EOS C50 camera users with the RF 600 lens experiencing the same issue?
I wonder how this can be reported as bug to Canon.
Thanks in advance.
01-10-2026 05:09 PM
Greetings MikeBill,
I am sorry to hear that you and your friend are having issues with the EOS C50 when attempting to shoot in high speed continuous using the RF 600mm F4L IS USM lens. We appreciate you troubleshooting the issue along with finding that this problem occurs with the camera bodies having different firmware versions installed. We would suggest on submitting your feedback directly to Canon USA. Please click on the following link and then select the feedback option located towards the top right of the webpage:
02-18-2026 08:44 AM
Canon confirmed the bug and advised that they released a new firmware, firmware 1.0.2.1, to fix this.
I can confirm that the bug is fixed with that firmware.
01-10-2026 05:09 PM
Greetings MikeBill,
01-11-2026 02:20 PM
Thank you. My friend and I raised a case with Canon Germany.
02-18-2026 08:44 AM
