04-04-2022 12:34 PM
Hi, I use my c100 mark ii for longer news segments and I need to self-tape stand-ups and interviews. Any recommendations on how to best focus and monitor the shot from in front of the camera without a second operator?
I know there are ways to hook up a remote control and monitor, but I'm not sure where to start.
Thanks!
04-05-2022 08:52 AM
Hi Maddieo
Thanks for checking in with us.
When self-recording you could try to set focus on something that is at a similar distance to where you will be standing and use a more closed down aperture like f/5.6 or f/8 to have more depth of field.
If you have the budget for it though, you may wish to get an external monitor that you connect to the camera by HDMI. With a long enough HDMI cable, you should be able to monitor the image from where you are recording.
We don't specialize in HDMI monitors, but there are companies like Atomos, Lilliput, and Small HD who do.
You may wish to check with some of our dealers like www.adorama.com, www.bhphotovideo.com, and www.samys.com to see if they have any recommendations that might work for your setup.
04-05-2022 08:52 AM
Hi Maddieo
04-05-2022 02:26 PM
Thanks! This is helpful, and I'm definitely in the market for a portable external monitor. Is there a way to control the camera remotely as well--either through an external monitor or a separate device? I would love to be able to adjust the focus from in front of the camera while monitoring it, if possible, rather than going back and forth. Thanks!
