01-26-2015 05:03 PM
Just installed Pixma Pro10 photo printer. The "My Image Garden" Software that came with it keeps "crashing." I downloaded and updated to the newest version and am having the same results. It runs for about 2 or 3 minutes and then stops with the error message "My Image Garden" has quit working. Windows will check for a solution." I am running Windows 8.
01-29-2015 10:39 AM
I have a suggestion which you may not like but is way better than MIG. Get Photoshop Elements and move on. PSE works very well with the Pro-10 which BTW, is a high end printer that really can show it's stuff with PSE.
Otherwise call Canon support and start the, ah .............procedure!
01-31-2015 07:48 AM
Thanks "Esteemed Eontributor!" I will check into it. Almost would rather spend money than "start the procedure!"
01-13-2020 10:11 AM
Having the same problem. Every time I try to scan and save as a PDF the program crashes. Have uninstaled and reinstalled. Any suggestions? I got this software with a new Canon PIXMA TR8520. Do I have to scan into my image garden? This program is garbage.
