‎11-12-2024
05:08 PM
‎11-13-2024
08:57 AM
#TR8520
I got Brutal with offloading stuff from my 🪟 11 PC some months back and I accidentally offloaded My Image Garden, which was my go to for printing and scanning.
I needed to scan something the other day so I went through the process of finding/downloading My Image Garden, as well as all the drivers that Canon says I needed. I would try to scan and I would get the following error:
IJ network scanner selector EX2 cannot be found. Reinstall scanner driver. Scanner driver will be closed. Code 3,208,0
I've tried installing everything in the software/driver section that might be related to that code and nothing works.
I don't use it much since I retired, but it would make life easier if I could when I need to.
Any suggestions would be greatly appreciated.
TIA
‎11-27-2024 03:41 PM
Hi KevininTucson,
Please follow these steps to resolve the 3,208,0 error you are experiencing with your PIXMA TR8520:
1. On your computer, please press the Windows key on your keyboard and the letter R, then let both go.
2. In the Run window that appears, please type CONTROL and click OK.
3. In Control Panel, click on Uninstall a program.
4. In the program list, please uninstall:
Canon MP Drivers
Canon IJ Scan Utility
Canon IJ Scanner Selector EX
5. Once uninstalled, please restart your computer.
6. When your computer reboots, please use this link from the Support page of your PIXMA TR8520 to download the drivers.
7. Please open that file once the download is complete and follow the on screen prompts to reinstall.
Please use the IJ Scan Utility to scan once the installation is complete.
Hi KevininTucson,
Canon MP Drivers
‎11-29-2024 06:37 PM
Hey Patrick! Just a quick note to say thank you! That worked perfectly and was an easy solution! My only only comment would be that I wish they would make that clear on the support page for my model. Again, appreciate your help!
