08-21-2024 10:15 AM
Hi. I've got a new computer in a new work area. All was working perfectly before when on laptop with printer close to internet box, but now that am too far away to connect via wifi the scanner part of the printer won't connect. I have a range extender but still a weak wifi signal.
The pc is connected to internet via a cable.
The printer is connected via usb cable to the pc box, and there's no problem with printing. In the printer settings it shows the printer and all is fine, but in it's scan settings it's not connected.
This is a new pc so all new drivers downloaded but I have nevertheless taken them off and reinstalled and same with Canon Image Garden app that I used on laptop.
A very basic MS scan app connects but the quality is appalling. The only element I can change is the dpi and even at 600 it's bad - it's like a very bad photocopy, all nuance removed.
I have downloaded Canon IJ scan utility too but that won't connect to the scanner/printer either
I need to work on pictures and will be scanning a lot, so I would much prefer if I can connect to my new pc and workspace.
I'm on windows 11 if that makes any difference.
Any constructive suggestions?
08-23-2024 08:44 AM
Welcome to The Canon Community, and thank you for your inquiry!
We appreciate your participation, however, we need to let you know that the Canon Community is hosted and moderated within the United States by Canon USA. We are only able to provide support for Canon products manufactured for and used within the US market.
If you live outside the United States, please CLICK HERE and select your country or region for your support needs.
You're welcome to discuss Canon products sold outside of the United States, but please be aware that you will not receive support directly from Canon USA.
08-23-2024 08:44 AM
