What to Do
Close the joint lever following the procedure below.
Open top cover.
Push joint lever securely.\Note
Push the joint lever until it clicks into place
Close top cover.
07-03-2026
05:15 PM
11:53 AM
the screen on my imagePROGRAF PRO-1000 says the joint lever is not closed completely. sure looks like it is to me. does anyone have any suggestions ? thank you
07-03-2026 08:15 PM - edited 07-03-2026 08:21 PM
Did you follow this procedure?
From the manual at https://ij.manual.canon/ij/webmanual/ErrorCode/PRO-1000%20series/EN/ERR/1881.html
Open top cover.
Close top cover.
07-03-2026 10:51 PM
Thank you !
07-04-2026 02:39 PM
Yes, I tried this but no sucess.
07-04-2026 08:25 PM
I should have included the next step, shouldn't I? Next, you should contact the Canon printer support team available Monday through Friday from 8am to 8pm (ET),and can be reached at 1-800-OK-CANON (800-652-2666).
You should make sure your printer is registered in your Canon account first, of course.
07-05-2026 10:45 AM
thank you again !
