11-05-2022
03:11 AM
12:19 PM
It seems I am unable to print small sizes on this software/ Canon Pro 1000. I am only able to create smaller sizes and use them when selecting plain paper as my media type. I am looking to print fine art, more specifically on Hahnemuhle 4x6 Photo rag. No other setting, including the Hahnemuhle am1xs will allow me to select or create a custom 4x6 size. Is there a way around this? Or more importantly, why is this?
11-05-2022 12:11 PM
Let me get this straight. You are saying you can print 4x6 on Canon brand 4x6 paper? You are saying your ICC print profile for Hahnemuhle 4x6 Photo rag won't let you print 4x6?
11-13-2022 11:06 AM
I can not print anything other than Generic Photo Matte Paper quality on this size format it seams. So I can't use the media type canon pro matte, hahne photo rag, any fine art paper in small sizes.
It is the media type I'm having troubles with, ICC applies fine regardless of size.
11-13-2022 11:42 AM
If the printer works with any paper selecting on 4x6 it shows there isn't anything wrong with the printer. It is functioning like it is told to. This means you have a software or setup issue. It could mean you need to reinstall the software you are using or even the printer driver or perhaps check for an updated driver. Or, it can be as simple as a goof in the software instructions to the printer. What software do you use? I use Photoshop and Lightroom.
If you could not print 4x6 at all, there is likely a printer malfunction.
11-13-2022 01:21 PM
I use qimage one, and canon print and layout. The only option to use 4x6 paper is through manual feed when using fine art media types but the manual feed does not have suggest or have the ability to alrign 4x6 or small paper sizes.
Curious if you can override the manual feed option to top feed with these media types.
11-14-2022 09:46 AM
"I use qimage one, and canon print (?) and layout. (?)"
I don't know what these are? How or whether they even work. My suggestion and advice is the d/l any one or all the Canon software for the Pro-100 and use them. DPP4 for instance. I know certain papers have certain limitations, if the Canon software will not allow it, I doubt you can do it.
Ditch the Qimage One for sure.
