imagePROGRAF PRO-1000 Canon color profiles not showing up in Photoshop
yukon819
I've been having a problem with my Canon color profiles not showing up under the "Photoshop manages color" drop down for some time.  Sometimes they are there and sometimes they are not.  I don't know if my Mac is hiding them or if it's photoshop or what, but when they were missing, I used to be able to go to printers in system preferences and add another printer and click the canon pro 1000 and it would create another driver (pro 1000 (2)...) and then the profiles would be there. I would have like 6 or 7 Pro 1000s on my Mac.  But now that doesn't even work.  I've deleted the printers and downloaded the drivers again and no luck. Does anyone have any ideas?
This didn't get published properly in my earlier post:
"The stock Canon Profiles are hidden and not automatically put into the library>Colorsync>Profiles location which makes profiles available to Affinity for instance.
They must be copied from here: library> printers> Canon> BJPrinter> Resources>  ICCProfiles>  -Then control-click on the printer you use ie. Pro 10 or Pro 100  [that one threw me] and choose in the dropdown menu: show package contents.   From there you see Contents> Resources>   All the profiles appear to be copied and then pasted in correct location:
 Library> Colorsync> Profiles "
35 REPLIES 35
jrhoffman75
Is your Mac an M1 Mac?
Perhaps the info in the above thread about placing ICC profiles in ColorSync folder will resolve the problem.
It is not M1. I’ll look into colorsync.
thank you, but I don't get those options.  The below photo is what I get.  And even if I open the package contents I don't see any profiles in there.  Is there a place to download the Canon paper profiles directly so I can add them to ColorSync?Screen Shot 2022-02-13 at 11.56.04 AM.pngScreen Shot 2022-02-13 at 11.56.04 AM.png
Update* After I open my package contents for my printer, (Pro-1000), this is what I see, and they don't seem to be profiles. None of those folders have any .icc files that I can see.Screen Shot 2022-02-13 at 12.17.24 PM.pngScreen Shot 2022-02-13 at 12.17.24 PM.png
jrhoffman75
Are you in your user area?
Try entering the path starting in the top level MacHD.
See the path at the bottom of my screenshot.
You were right. I was not in the right pathway. This worked perfectly. I can't thank you enough!!!!! Finally!!!
jrhoffman75
Glad I could help.
jeanmr
Which file did you use for a pro-1000?  I'm having the same issue - this is new.  I'm on a mac running Big Sur.  I see my profiles for non-Canon paper, but the Canon profiles disappeared.
