02-15-2017 04:59 PM
If I'm blind please help me out. I just installed Print Studio Pro and I can find nowhere that allows me to set the print size. I've got letter sized paper and I want to print an 8x10, How/can I set the image to print 8x10 and an 8.5x11 inch sheet of paper? If not, is this not very basic functionalty?
02-15-2017 09:14 PM
See here:
02-15-2017 09:28 PM
02-15-2017 09:38 PM
02-15-2017 09:42 PM
If you look towards the bottom of the panel you will see Image Size.
10-15-2017 11:42 AM
Hi, FYI the answer on the linked page didn't help me because I had selected a borderless custom size w/o realizing it. You only get the dialog to adjust print size and margins if you select a bordered print option. Hope this helps somebody!
01-20-2018 10:50 PM
I have tried every margin, image size and position setting combination I can think of but printing a 460mm x 820mm landscape is only possible with 250mm of paper wastage after the print. Is there any way to set a margins without Print Studio PRo wanting to change my print size?
Eg: Top 10mm, Bottom 140mm, Left 10mm, Right 10mm this would leave me a print of 460 x 820 with no paper wastage
Print Studio Pro will not let me do this and I have; Top 10mm, Bottom 140mm, Left 10mm, Right 252mm
The bottom margin is inavoidable but the right magin is all wastage.
Mark Thompson
01-20-2018 10:56 PM - edited 01-20-2018 10:57 PM
What paper and media type selection have you made.
What editing software you using.
01-21-2018 04:26 PM
I'm using 24" roll on a PRO2000, papertype and size are checked and correct.
I shoot Canon RAW, develop in Canon Digital Photo Profesional and print with Print Studio Pro.
I wasted a bit of paper yesterday but finally turned my landscape photo to portrait in Digital Photo Professional and then Print Studio Pro would print without the excess paper. It looks like an issue when you rotate within Print Studio Pro.
02-25-2018 06:16 PM
It would be awesome if Canon's software had a PREVIEW. What you see is what you get. What a concept. I haven't found that option, even under "other options" in Printer Settings.
