01-21-2015 01:12 AM
Hi everyone
I own the pro100 printer since 2 weeks. I could make some nice prints from the Lightroom (5.7) print module using my wireless network. I just add recently the plugin "print studio pro" but I cannot make any print. Once the plugin starts (after clicking on one image, then plugin extras, then print studio pro), I have an error message (i translate from french) " no supported printer was detected by the software. Connect a supported printer then install the driver. Print studio pro will turn off."
I got the message even I am able to print from the lightroom print module (wirelessly).
My computer is an imac running Yosemite (10.10.1).
Thanks for your help
Emilie
01-22-2015 12:36 PM
On my MacBook I check the plus "+" symbol under the Printer section. (My Pro-100 is connected via WiFi.) It took a few seconds for the IJ version of the printer to show up. The Bonjour version appears first. Once I connected to the IJ printer I deleted the Bonlour printer (using "-" button.)
01-22-2015 12:45 PM
Be sure you have installed the IJ Network Tool if it isn't already installed.
01-21-2015 06:03 AM
When you add the printer to your computer in System Preferences be sure you select the Canon IJ version, not the Bonjour version. That may address what is happening.
01-21-2015 10:43 AM
Emilie,
Just curious, why do you want the Canon plug-in? You can do everything you need with just LR. Can you not?
I have the Canon plug-in installed and working on both my CS6 and LR5. I never use it.
I suspect the plug-in is not seeing your network.
01-22-2015 12:24 PM
How can I choose the Canon IJ Version when I add the printer ?
I removed and added the printer, no options were suggested.
Thanks
01-22-2015 12:25 PM
I just want to try it, I am not very in love with the LR print module...!!
01-22-2015 12:36 PM
01-22-2015 12:45 PM
01-22-2015 01:49 PM
"... I am not very in love with the LR print module...!!"
I can't blame you there as I am not a big fan of it either. My remedy is to print from Photoshop which in my opinion is very much better than LR.
01-26-2015 05:16 PM
OK, I will try photoshop...
01-26-2015 05:18 PM
Thanks, I realized I did not have installed IJ network tool.
Also I suspect there were a conflict with my other printer (Canon MG5300), I think i resolved by removed this printer, then open Canon studio pro, it reccognizes my Pro 100, then I added again the MG5300 and it is still working...
Now I can try this plugin
Thanks !
Emilie
