Problem Adding Paper Size to Pixma Pro 100
aptillie
I woudl like to add a few sizes of photo paper to my Pixma Pro 100. I go to Print Setup, then to Properties. I then go to Commonly Used Settings. There are Standard, Photo Printing, Business Document and Paper Saving categories to pick from. All of them except Photo Printing allow for a custom size when you go to select from Printer Paper Size.
Can someone explain how I can add custom size papers to Photo Printing?
Thank you
5 REPLIES 5
jrhoffman75
Thank you
The Photo Printing preset has Borderless Printing selected. Borderless Printing does not allow custom paper sizes.
Uncheck that option and save it as a new preset. - maybe Bordered Photo Printing.
I'll give that a try. Also I have never updated the driver from the original when I bought the printer. Shoud I do that as well or doent that matter. Im using the printer on Windows 8.1 printing from Lightroom and Darktable
Thank you
If the printer is working OK I wouldn't update the driver.
You can look on the website and see what has been added and determine if it matters to you.
I know the latest driver added two papers that I don't use.
All good following your instructions. Printer seems to be working fine, sometimes has a hard time picking up paper from rear tray. I think you are correct and will not update driver.
Thank you for your help!
Gald to help.
I have the same situation - the rear tray is very fussy.
