09-16-2021 09:08 PM
I'm trying to print a matte borderless 13x19 print and keep getting black streaks and lines at the bottom. I can even hear a scratching noise from the printer when its nearing the end of the paper. I've run the roller cleaner and bottom plate cleaner but that didnt help. I am printing a light cream color over the whole paper even the the photo it looks like plain paper. I've printed on a paper thats the same thickness but its bad quality (its the paper that comes as a cover/protection sheet to the professional paper.) and it printed without the lines on that one. My printer is set to A3+, Matte and I've never had this issue before. I need to send this print out tomorrow for a customer and I can't figure it out!
08-01-2023 01:44 PM
You can try adjust the paper abrasion setting. Please click HERE for more information.
09-17-2021 08:33 AM
Welcome to the forum.
I suggest you go into your printer driver and try setting an option like this: (Ihave the Pro-100 but I suspect you would find a similar setting)
07-30-2023 03:09 AM
I've experienced the same issue, could you reply with the solution back again? I think the screenshot you attached above isn't showing correctly.
08-01-2023 01:44 PM
08-01-2023 02:07 PM
This worked!
Thank you Arthur. Since I did not begin this chat, i cannot find a button for accept this as a solution.
I did start this chat though, so if you comment there, i can accept it as a solution and it will help alot more other folks.
