01-27-2019 08:04 PM
I've learned the Pro-1000 uses at least a smidgin of ink clearing the printhead every time you turn it on. Some folks suggest just never turning it off, to save that smidgin of ink. Will doing so harm the printer? Is there enough heat generated to be of concern? Thanks.
Oldshooter
01-28-2019 10:28 AM
I can't comment directly on the Pro-1000, but I have a Pro-100 that has been always on for several years (other than a few power outages) since it is configured for wireless printing from two of my computers.
No problems, and there is no place on the housing that feels warmer than room ambient.
01-28-2019 06:02 PM
01-30-2019 10:45 AM
Jose Rodriguez YouTube channel on printers talks about this (though not specific to the Pro-1000).
To avoid the printheads from drying out, Canon has a timer which periodically clears the heads. But apparently there are different levels of aggressiveness on the cleaning cycles. Canon normally runs the least-aggressive cycle (the one that uses the least ink possible) if they know how long it has been since the last cleaning cycle.
The trouble is... if the printer is deprived of power, it has no internal battery clock ... so it has no idea if it's been powered off for 1 minute vs 1 year and ... that triggers the MOST aggressive cleaning cycle (which uses the most ink).
So Jose's recommendation is ... turn it on and leave it on. This minimizes the amount of wasted ink.
02-02-2019 02:30 AM
Well, gang, I turned on the Pro-1000, thinking I'd never turned it off. But CANON WINS! I'll still be blowing off ink......because there is an internal timer, apparently, that shuts the printer OFF after, what? an hour or so without being uses? Then, when you turn it on again it goes through the ink-wasteful routine of head cleaning....
02-02-2019 11:26 AM
If you go into the printer driver and select the Maintenance tab do you have an option for Auto Power with Disable as an option? This is my Pro-100 driver.
02-02-2019 01:12 PM
John, thanks a million, but I'm too dim, apparently. How do you "go into the printer driver?"
02-02-2019 04:51 PM
Hey, John,
I got it. I got it. I got it. Dug throught the Utility menu, and there it was. Disabled the Auto Power Off (default was 240 minutes). Thanks again.
Oldshooter.
02-02-2019 04:59 PM
05-17-2019 01:36 PM
John, how is this working for you?
I bought my Pro-1000 in 11/2016. I've filled four maintenance tanks. A friend with a 10+ year old Canon 17" printer is on his second maintenance tank.
Since no cleaning cycles will be done with leaving the printer on, have you encountered clogs?
Thanks, Hal
