12-07-2016 01:00 PM
Pro 100. Paper shifts on exit from the machine ruing the last several inches of the print. Also a noise change at the same time as the paper shift.. Anyone have any ideas? Printing documents is fine. Printing on plain or matte paper is fine. Only when I print photos on Kodak Basic Glossy Paper.. Package says compatible with Canon printers. It's the only photo paper I have.
12-07-2016 03:15 PM
1. what media type are you selecting when you print?
2. are you printing from rear tray or manual feed?
3. have you tried roller cleaning?
12-07-2016 05:03 PM
12-07-2016 05:09 PM
12-07-2016 05:20 PM
02-25-2018 05:04 PM - edited 02-25-2018 05:05 PM
I am having the same issue with 8.5"x11" paper when I do various size prints on it, but not on 13"x19" (though I haven't tried this in a while). I am using the Canon pro luster paper in both instances I have only used the rear tray. Did you get any resolution with this?
02-25-2018 08:24 PM
12-01-2019 05:20 PM
This only happens when using 13' x19" paper. Paper is standard weight glossy. Print set at A+ 13x19. Prints well until about last inch or two, then a grinding sound (coming from right?) as paper shifts to left about one-quarter inch. .Driver is current. Running Win10. Odd thing is about 1" of very bottom vertical edges (portrait setting) are crimped/folded up slightly, obviously pushed by somehting. This only happens with this size paper, others no problem. Appreciate any clues you might have.
12-01-2019 05:33 PM
You'll have to play with paper type setting especially if using non Canon paper. The printer is thinking you're using a thicker paper and not gripping it tight enough, especially as more of the paper is past the rollers and is being pushed rather than pulled.
12-01-2019 06:31 PM
Thank you, thank you!!! Your suggestion makes all the sense in the world. Having burned up enough ink and paper for one day will play further as this is not Canon paper and suspect we will try for something thinner tomorrow. Again, thanks! Mark
