09-27-2022
02:15 PM
09:43 AM
New printer. I got a couple of good prints to start with. But now I get a faint vertical banding. I tested for clogged nozzles. They're okay. Checked alignment. Okay. I'm sure I'm selecting the proper paper type. Not sure what to do next. Hate wasting all this A3+ paper and ink.
10-03-2022 01:18 PM
I spent over an hour on the phone with Canon support. The guy I talked to was very patient and was as helpful as he was able to be. But he wasn't able to come up with a solution. So I am returning the printer to Amazon where I got it. Interestingly, their price for a new one went up $200. I ended up ordering one from B & H Photo. I'll have it in two days.
09-27-2022 02:22 PM
Hi, flip!
So that the Community can help you better, we need to know exactly which Canon printer model you're using. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
09-27-2022 03:49 PM
Yes, it is a Pixma Pro-200. Paper type set at Plus Semi-gloss, but it is Epson Premium Semi-Gloss paper not Canon paper. Perhaps that is the problem, although I got two decent prints on the Epson paper prior to this one. I hate to switch paper and waste the ink only to find out that isn't the problem. But perhaps that's the next option. Printing from Photoshop 2021. Can't think of any other details.
09-28-2022 02:03 PM
Hi flip,
Because this issue may be hardware related, it is recommended that you contact technical support via phone for further assistance. There is NO charge for this call. Please dial 1-800-423-2366, Monday-Friday 8:00 am to 8:00 pm Eastern Time, excluding holidays. A Technical Support Representative can determine the cause of the lines you are seeing on your printouts and resolve it or provide you with your available service options.
09-28-2022 02:12 PM
I agree with Patrick that you should contact Canon. Using Epson paper and the canon ICC profile might result in some color issues, but it shouldn't be causing lines on your print.
10-03-2022 01:18 PM
