12-03-2020 11:33 AM - edited 12-03-2020 11:36 AM
After downloading to the latest version of OS, (BIg SUR) the image in the Print dialog of Lightroom shows the unedited version. I'm using a Pro 100 printer. Anyone know a fix for this?
12-03-2020 03:47 PM
I don't believe the print module display has anything to do with the printer.
As a test, choose "Print to File" as an option and see what happens.
Exactly how are you selecting the edited image. Is it showing in the Develop module or are you choosing from the Library module?
12-04-2020 09:03 PM
After printing "to file" the image had all my corrections included and I had made a small print that showed them also. I'm jusrt used to going from the Develop module to Print module and still seing the same processed image.
I"m probably posting this in the wrong forum anyway.
12-04-2020 10:21 PM - edited 12-05-2020 07:48 AM
That is a real mystery.
I frequently make prints and then send the same image print to file. I've never experienced what you are describing.
Try this - select an edited file in the Develop module and switch it to Adobe Monochrome. Then switch to the Print module. If it isn't monochrome in the Print module then maybe head to the forum at lightroomqueen.com and post there.
It's not a printer problem.
12-06-2020 05:41 PM
Yeah tried what you suggested and it showed up in the Print module as a B&W. I think I'll post on the Lightroom forum and see If anyone has seen this. Thanks for your suggestions
12-06-2020 06:03 PM
If it is showing up in the Print modle the same as it is in the Develop module then I am not understanding what the problem is.
