How do I print borderless 11x14 on my pixma pro 100?
ST
First off if you use Photoshop at all, you are NOT computer "stupid".
I use the very same set-up as you.
This is how, right or wrong, I do it. It is best to use the Image Size function in PS to make your photo the exact size you want it to print. (This is not necessary but it does make it easier.)  So in your case make your photo 11x14. Select Print from the File drop down. This brings up the Photoshop Print Settings screen. Make sure your printer, the Pixma Pro-100 is displayed in the Printer window. How many Copies? Select Printer Settings. Set your printer to 11x17 or 13x19 paper and the rest of the pertinent stuff. I know you want 11x14 but Canon does not have that selection as it is not a standard paper size.
Under Color Handling select Photoshop Manages Colors and make sure you turned that feature off in the printer.
Select your profile. Normal printing and Perceptual. Under Scaled Print Size enter 11x14.
Down on the left side of the window is Match Print Colors, check that.
Click "Print".
There are other ways as is everything with PS but this will work. Oh, BTW, trim your finished print to 11x14.Smiley LOL
9 REPLIES 9
jrhoffman75
I think you open the printer driver and select Page Option -> P:age Size -> Custom (input size) and then select Borderless.
ebiggs1
What software are you using? It should not be a big deal and a fairly easy setting.
jrhoffman75
Here is a resource: http://www.redrivercatalog.com/infocenter/tips/custom_inkjet_paper_size.html
Thanks so much, I love red river papers, never thought to look there. Have a great day.
Hello, I should let you know right up front, I am very computer stupid, I use photoshop cs6.  Any advice would be greatly appreciated.  Thanking you in advance.
Click "Print".
I tried to use the suggestions here, but with input of 14X17 printing at 11X14 from photoshop I got an 11X12.6 print on my 11X14 paper.  Close but not there; I need help.  Thanks in advance.  Pixma Pro 10 printer
Was your aspect ratio sufficient to fill a 11x14 page?
How to Print Borderless 11x14 Photoshop / Canon (redrivercatalog.com)
"I got an 11X12.6 print on my 11X14 paper."
What did PS say here?
My print is 12x9 but yours should say 14x11.
