05-04-2019 02:50 PM
Hello,
I am using a Pro-10 with a Mac. When printing B&W from Lightroom I choose Managed by Printer for Color Management. I understood that to mean that the printer would manage how the ink is put down.
In the print dialog box with Black and White Photo Print checked, I see under Color Matching that there is the option to use ColorSync or Canon Color Matching. I always assumed I should use Canon Color Matching however when selecting ColorSync I have the option of selecting a paper profile. I am pretty sure I should be using Canon Color Matching but now I am a little uncertain.
Can someone confirm if Canon Color Matching for B&W printing is correct?
Thanks.
05-04-2019 03:11 PM
If you select Canon Color Matching you don’t get to choose an ICC profile since the printer driver will match the correct Canon profile for the media and quality selection you make. If you are using Canon paper that’s OK. If you are using third party paper then you need to select ColorSync.
05-04-2019 03:11 PM
05-04-2019 03:13 PM
Thanks John.
