07-07-2018 04:12 PM
07-10-2018 07:56 PM
@jrhoffman75 wrote:
Are you making any adjustments to your image before printing? One possibility is that your new monitor out of the box is set for web viewing. That is generally a bright setting and a 9300K white point. If you adjust your inage based on those setting (and your old monitor didn’t have those settings) you may get incorrect prints.
Definitely print the test image Tim identified. Very important is to not make any adjustments to the test image before printing, regardless of how it looks on screen.
No adjustments to the image prior to printing. The monitor is set to 6500K. I will print the test page suggested by Tim. However, I am not clear what it is supposed to show me.
07-10-2018 08:12 PM
Ok... the test image printed beautifully! So, that's not the issue
07-10-2018 08:29 PM
07-11-2018 09:12 AM
All is well now. I am guessing here that perhaps the image I was using to print on the 13x19 paper was to small. I used a larger size of the same image and tried printing again and this time it looks perfect.
07-11-2018 09:20 AM
Thats good news.
