08-21-2016 10:41 AM
I have Canon Pro 100. I print from a MAC pro. I am having a problem with my printer settings. For most photos I cannot use the "fine" or even the "standard" setting. The only option is "fast on plain paper" . The only photos that will print in "fine" on photo paper are those taken with my Iphone and and IPad and they are spectacular (including a panorama on 13 x 19 paper). I am using the Canon Image Garden program for printing. Image Garden cannot seem to find all of my photos. I have to put individual photos on my desktop to enable Image Garden to find them. Even that does solve the setting problem. For example I added a photo from Desktop to Photo Layout. Under Advanced Settings I chose print quality "high". I hit print and a box appeared telling me to be sure to use the defautl setting. When the Print Box came up the Printer box showed Canon Pro-100 series, the Presets box showed "Fast Printing on Plain Paper". There was no other option. Honestly, I cannot find the Default Settings. Help wanted!
09-03-2016 01:32 PM
My Image Garden is a very limited program. You are using the correct approach with Photos.
08-21-2016 03:07 PM
I suspect your problem is that you are using the Bonjour version of the printer.
Have you installed the Canon drivers from the CD that came with the printer?
After the driver has been installed go to the System Preferences, Printers and Scanners and click "+" to add printer.
Wait, could be a few minutes, until the IJ version of the printer shows up. Bonjour printer version is very limited and won't let you take advantage of Pro-100 capabilities.
What software do you use for photo processing?
08-21-2016 04:55 PM
The CD that came with the printer did not list the undated MAC OS that came with my computer. I consulted this forum, following the advice I got, I downloaded the driver from support. Do you think I downloaded the wrong driver? The software is the software that came with the printer for "the Pro 100 series." The component I used is Image Garden. I do not recall seeing the word "Bonjour" anwywhere. Should I go back to support and download again?
08-21-2016 05:22 PM
Are you connected via USB. Do you see pages similar to this:
08-21-2016 06:09 PM
i am trying to screen shot the pages but am failing. I am connected by USB. I do not get the first screen. Rather I get the Canon Quick Menu which shows Pro-100 series. From that I get the Image Garden which similar to your second page. In the end, get which I believe is the Apple print dialogue page which Canon Pro 100 as the default printer.
08-21-2016 06:33 PM
I guess thats a limitation of My Image Garden. Do you have other software you use to edit your photos? What about "Photos" on the Mac?
08-22-2016 07:39 AM
08-22-2016 07:42 AM
Give Canon a call at 1-800-OK-CANON.
08-22-2016 09:41 AM
Ok Thanks much for your efforts.
08-22-2016 10:25 AM - edited 08-22-2016 10:30 AM
One last thought. Have you created a preset with all your printing selections, saved it and then recalled it for printing?
