07-20-2020 09:19 AM
I am having issues with the print head being too close to the paper/ cards I am printing on. As I print, some of the cards have this issue where the ink showes clear paths the ink head took as it went accross it. is there a way to raise the print head somehow? I have tried printing through both the manual and top feeding trays with no difference.
07-20-2020 10:53 AM
Welcome to the forum.
You can set this in the printer driver.
It can help. but depending on the cardstock stiffness it may not totally eliminate the problem.
07-20-2020 10:57 AM
07-20-2020 10:59 AM
07-20-2020 11:01 AM
07-20-2020 11:12 AM
If you go to Devices and Printers in the Control Panel you should see this.
Here is where you find the latest driver.
After you are sure you have the latest driver i nstalled here is how you can access the head abrasion setting.
I will be away from computer for a while now.
07-20-2020 01:53 PM
Thank you so much! I will try this as soon as I get home.
07-27-2020 04:09 PM
Hello TheCobaltKnight,
I agree, turning on the prevent paper abrasion setting to see if that resolves the issue would be your best option. If you still have the issue after changing the setting, it would mean there is some curling in the paper or the paper is too stiff/thick for the paper path. You can try laying a single sheet of the cardstock on a flat surface to check for any curling.
To see if there are any other suggestions or settings that you can change, please reply to this message with the specific type and size of cardstock that you have and we will try to assist further.
