10-24-2015 10:43 AM
Canon's calling the "top" printer the "rear" printer is utterly confusing. In any case, I can' seem to get the printer to make use of the "back" printer, the part that prints up to 13x19. Any help here?
10-24-2015 06:12 PM
10-24-2015 08:15 PM
You said you've printed, so we can assume printer is installed correctly onto Mac.
I opened a document in Pages and selected print and get the same printer window as I posted earlier.
It happens automatically when I select print, with the same required to show detail as I discussed earlier.
The first thing you need to do is to get this window open in Pages. Then, if you can't get it in your graphics program its a program issue.
10-24-2015 11:20 AM - edited 10-24-2015 11:22 AM
I would agree with your opinion that the Canon nomenclature isn't intuitive.
The slot on the rear panel is called the Manual Feed Tray. Select the Manaul Feed Tray to use it.
I put 13x19 sheets into the top loading Rear Tray all the time, BTW
10-24-2015 11:41 AM
And select Manual Feed in print setup.
10-24-2015 12:12 PM
10-24-2015 12:14 PM
This seems to be instructions for a pc, rather than a Mac. I seem to have no access anywhere to the manual feed.
10-24-2015 12:27 PM
Did you install the Bonjour option or IJ Network version. You want the IJ version. I'll get on my Mac and get to driver there.
10-24-2015 01:09 PM
I am not familiar with your software, so I can't help you get to the driver screen, but this screen appears when I select Print in my software.
You need to be using the IJ Network version of the printer. If you don't have it go back to printer installation page in System Preferences and add it via the + sign.
If you don't get this large window then the yellow highlighted "Hide Details" will say "Show Details" nClick it.
On the right side the yellow highlighted "Quality & Media" is a dropdown option. You can select many options.
When you are all finished selecting what you want you can create a preset that you load the next time and all choices will be where you want.
10-24-2015 04:39 PM
I love the look of your software. Unfortunately, it seems to be for camera only. I tried to download it from Canon but it asks for which camera I have. Your various directions don't seem to have application to my printer. 😞 You refer to the IJ version of the printer. Do you mean the IJ printer network SOFTWARE? Or is there separate s/w for the printer installation itself? (You may be able to tell here that I'm not a deep died techie! :/)
10-24-2015 04:58 PM
10-24-2015 05:34 PM
