PRO-4100 paper source "Cut Sheet"
ld47
Print Settings:
Paper Size:
  • Letter(8.5"x11")(8.500x11.000)
Paper Source:
  • Cut Sheet
Layout:
  • Alignment: None
  • Move Slot: None
  • Image Slot Position/Margin:  Image Slot Position/Margin
Currently what I see in the layout is a horizontal dark gray rectangle with a horizontal white printable area rectangle, even though I'm not in landscape view.  There is an area on the right side that looks like it is not printable.
Why is the page orientation in landscape?
When I feed this sheet into the 4100, does it feed in short side first or long side first?
In other words, how do I tell in advance which side of the paper will have the extra non printable area?
Sonya1
Hi Id47,
When you load cutsheet into your imagePROGRAF PRO-4100, you should feed in short side first. Keep in mind when printing on cut sheet, we recommend a margin of 0.8 in. (20 mm) on top, 0.8 in. (20 mm) on bottom, and 0.2 in. (3 mm) on left and right sides is required. However, the bottom margin for cut sheet depends on your OS and applications. In regard to your image, you have selected to display the paper horizontally, see your example below. I hope this is helpful.
2 REPLIES 2
ld47
I fed the sheet into the printer short side first.
The far right side (dark gray non printable area) left a 3/4" (2 cm) white space that the rollers hold on to.
Sonya1
Hi Id47,
