ts 3122 trying to hook up to a verizon jetpack
leeheelan
I have a ts3122.  We use a verizon jetpack for internet now.   I can not get my printer to hook up to it.  Help.
1 REPLY 1
While what you are trying to do is possible, and JetPacks allow address reservation..  this is not an ideal way to manage printing on a permanent basis.
Below are the requirements:
JetPack must provide a dedicated 2.4Ghz broadcast
Security: WPA or WPA2 PSK
Don't use the same SSID name if the Jet Pack is dual band (2.4 / 5Ghz)
My suggestion:
Use a USB cable and connect your printer directly to your computer.  This will be the most reliable and require the least amount of management.
