imageCLASS LBP6030w -Wi-Fi setup-Wont connect
PhilG20
I reently switched from xfinity wifi to verizon wifi and now my printer will not recognize me desktop and print. Printer is searching for a signal but won't connect.
1 REPLY 1
The printer supports a 2.4Ghz broadcast that uses WPA2 encryption.  Please ensure your new router/network supports these standards.
It might be helpful to create a dedicated 2.4 GHz broadcast configured with WPA2.  You can do this by giving each broadcast a unique name.  If all broadcasts use the same name, you can temporarily disable the 5, 6, or 7G broadcasts while making a connection then turn them back on.  Many new routers come pre-configured for WPA3 encryption.  You can use WPA3/WPA2 for backwards compatibility or WPA2.  The printer cannot connect to a network that utilizes WPA3 encryption exclusively as this standard is not supported.
