01-05-2018 11:02 AM
Hello, I recently changed the wifi setting of my network, we changed the network password, and now the printer is offline and I haven been able to reset it. I tried connecting it to my mac and going through the setup again, but it doesn't work, the wifi light blinks fast and the cancel button lights up, y restarted the router. I'm trying to follow this instructions here http://gdlp01.c-wss.com/gds/1/0300008421/01/PRO-10_PRO-100_NonPC_EN.pdf but I don't know what the access point is? How can I fix this?
Thank you
01-08-2018 08:12 PM
thanks, I didn't realized that I had to erase my old settings of the printer and add it again as a new printer, now it works.
11-27-2021 03:14 PM
I need an easy fix. looks to complicated, please
11-27-2021 04:26 PM
I had to find my cable and connect it via usb. I cannot find my original set up disc, and I just cant get it done without it. Im lost. ugh
11-27-2021 04:31 PM
You can download all software from here. Don't need CD.
11-29-2021 02:13 PM
How can I order a new or replacement setup cd/disk for my pixma pro 100, please?
11-29-2021 04:05 PM
@coolvanstuff wrote:How can I order a new or replacement setup cd/disk for my pixma pro 100, please?
I don't know if Canon sells them, but even if you could it would be an 8 or so year old item.
The latest versions of all software are on the Canon support site.
11-29-2021 08:03 PM
11-29-2021 08:07 PM
Download / Installation Procedures 1. Click the link, select [ Save ], specify "Save As", then click [ Save ] to download the file. Memo : If you select [ Run ] ( or [ Open ] ) instead of [ Save ], the file will be automatically installed after it is saved. 2. The downloaded file will be saved in the specified place in the self-extracting form ( .exe format ). 3. Double-click the downloaded EXE file to decompress it, then installation will start automatically.
What link1?
All I get is this>>
p86I_win_pro_100-....exe
There is no thing to click run after thge install. I just want this to be wireless on My new ATT interent. I flat need lamens terms help. please
11-29-2021 08:49 PM
11-30-2021 12:58 AM
I found my **bleep** and it transferred all updated drivers to the new install. I think downloading ther drivers from the internet is good, but you best have the cd. IMHO
11-30-2021 04:48 AM - edited 11-30-2021 04:50 AM
Many people don't have computers with physical drives that play discs anymore. I don't. I've never used the disc and I've never had issues with the driver install - I just downloaded the files from the internet as was suggested and read the information in these forums.
To each their own. You might want to take some time to review YouTube videos about this printer. The ones from HBT and jtoolman are good. This is a very powerful printer and you will need to educate yourself on how to make your printer head and cartridges function without issues. There's a lot of technical information to know to keep your printer purring over time. Good luck!
