"another computer is using this printer"
mx 922 often says "another computer is using this printer" and won't print even when there is only one computer on. Win 7
I have a iMac and Canon MB5440 printer with a HUAWEI wifi router. My printer regularly loses connection with the router and gives the following error message: Support Code : 300 The printer does not respond. Make sure that the printer is plugged in, ...
Hello, how are you today i just wanted to ask how would i find my WPS button to my printer to add it so print my picture ...
Got a new router, connected laptop to router, connected printer to router - both listed on my routers device list. When I try print from laptop it can't find printer. Can you help please? I have other devices I will need to connect later too.
Hey all, I have cannon TS 3170S. My printer worked wirelessly only for a day, and now for the past three days it is only working on USB. I am using a MAC book pro with High sierra ( ver. 10.13.2 ). The print does not seem to be working from any of my...
I just upgraded to a Win10 computer and my MG6220 is not working. It is connected to my home network via wireless. All other devices print to it. However, when i install the new print drivers, an displays indicating it can not find the printer on ...
When I tried to connect my printer to my new Netgear AC1750 router, It asks me to press the WPS button on the router. There is no WPS button on the router. Someone told me to press STOP and try Wireless Lan setup and standard setup. It found my rout...
Good Morning, I'm a new member. My Wireless Priner had been working just fine until yesterday when it went offline. I can't seem to locate in my manuals how to trouble shoot this issue. Everything else appears to be just fine. Printer is on and conne...
I have a new TS8020 that I'm trying to use with a windows 10 laptop. I've installed the software on the laptop and tried to do the easy connect setup but when it gets the the list of wifi points my home router isn't shown. I tried to manual enter the...
I've reached my wit's end. Suddenly the printer won't print. Router connection w/ Windows 10 64bit I have: reloaded drivers x4reset the WPS on the router x4rebooted my PC x4re-initialized the printer x2 Is there something else that I need to do? I r...
Hi. I tried to use my scanner yesterday and it says the MP Navigator driver did not install correctly. I have not changed anything. I uninstalled and reinstalled per error message suggestion. I reinstalled from the Canon website. I am using Wind...
I just set up my new MX922. No manual. Have no idea how to scan a document.
Does anyone know if this can be done easily? My Archer C7 / TP- Link router has 2 USB ports for connecting other devices, including printers. I want to connect the MX922 via a USB cable to the USB port on the router, thereby making it accessible to a...
Good day. I've recently installed an LBP6230 as a wireless printer. I can successfully print via wifi from multiple windows PCs. However, if I try to submit a job from my android phone (Samsung galaxy S7, connected to the same network), I get the mes...
| Subject | Author | Posted |
| 09-15-2026 07:21 PM | ||
| 09-13-2026 07:01 PM | ||
| 09-10-2026 02:37 PM | ||
| 08-14-2026 05:48 PM | ||
| 04-28-2026 08:20 AM |
