Printer Software & Networking
MacOS setup.app will not run
Hello... I just bought and installed a TR4520 multi-function printer. In order to connect it wirelessly, I'm supposed to run setup.app, which I downloaded from the Canon web site. It doesn't launch on my iMac running MacOS 10.14.6. I don't get any er...
EricRFMA by Contributor
  • 5293 Views
  • 3 replies
MX492 scanning Chromebook
I bought the MX492 to use with a Chromebook. Printing works fine with Google cloud print. Scanning does not work. I tried plugging to laptop into the printer with a USB, but that didn't help. I can scan using the Canon/SELPHY app on my android phone....
Gb1 by Apprentice
  • 24332 Views
  • 8 replies
MF644cdw system ID and PIN?
I am trying to set up the "scan to email" function. I checked the user's guide, and seems like I first need to know the network settings. But it asks my System ID and PIN. I don't recall I set one up. How can I find it, or, re-set it?
Chromebook compatible printers
I have a Canon Pixma MG3022 printer.  Is it compatible with a Samsung Chromebook?  I haven't been able to figure out how to connect it to my Chromebook.   I do have a USB cable.  Help!  I am told that Google Cloud Print will end in Dec. 2020.   What ...
MX922 Canon IJ Scan Utility broken!
My MX922 is Wifi set up with my older iMac OS 10.11.6.  Canon IJ Scan Utility Version 1.1.1,  Canon IJ Network Tool (Driver) Version 4.7.2.  When I use the Canon IJ Scan Utility, it completes the scan and prompts me to "Exit" or continue to "Scan".  ...
romil01 by Enthusiast
  • 5226 Views
  • 6 replies
My PIXMA MG 3620 isn't working..
When I first bought the printer earlier in the year, I was trying to connect it to my iPad which didn't work. Now I have a MacBook Air and I am trying to connect it to the laptop. It says to reset the printer, I need to hold down the stop button unti...
Resolved! printer not found, sometimes
My Windows 7 desktop (has ethernet to router) and a Macintosh desktop (over wifi) has /intermittant/ issues being able to see/find my Pixma TS3320 (wifi) on my home network.  Strangely, whenever this happens, my Windows 7 laptop (over wifi) does *not...
gherson by Contributor
  • 10481 Views
  • 5 replies
Canon Pixma iP7250 Network Problem
Hi guys!I bought a Pixma iP7250 last month on Amazon.de There are only 3 button on printer so that's cannot be complicated connection at all.On user manual it says press hold wifi button a couple seconds and then press WPS button on router.That's it....
TS5320 won't connect to wifi
I just got a TS5320 and it won't connect to the wifi no matter what I do. when I try doing the manual set up it doesn't prompt me for a password so that method doesn't work and when I try doing it through the master setup it says it can't detect my p...
