10-14-2015 03:43 AM
10-14-2015 09:36 AM
If your router requires a PIN code it will usually be printed on the router.
10-15-2015 02:33 PM
@jrhoffman75 wrote:If your router requires a PIN code it will usually be printed on the router.
If not, then it should definitely be accessible through the router's admin utility. It would probably be best to connect to the router with a network cable when you put it into "admin" mode to change its' settings.
