‎03-04-2024 07:56 AM
I'm trying to use the Canon Professional Print & Layout software to print from my Mac.
It seems like I'm unable to load CMYK files in to the application to print. When I select the file, nothing happens and the file is ignored.
I've tried this with both TIFFs and JPGs - they load up alright when in RGB colourspace but fail if they are CMYK.
I don't want to have to transform all the files to RGB first as this may affect the colours from the original artwork.
Does anybody know if this is a bug or expected behaviour - I can't see this restriction listed anywhere in the documentation. Is there any workaround?
‎03-12-2024 05:58 AM
I've just had a response from Canon support confirming that this is the expected behaviour for this software - you cannot print CMYK files to your CMYK Canon printer using Canon software. Mindblowing.
"In response to your enquiry regarding the Professional Print & Layout, I am attaching below the link with of the software's manual with the general notes.
Professional Print & Layout Guide
General Notes (Professional Print & Layout) << Click the link
When starting from supported application
Therefore, as you correctly mentioned, this software does not support CMYK files and unfortunately I could not find a workaround.
Lastly, I am attaching below the link of an article with information regarding the RGB and CMYK colour systems.
RGB, CMYK and photo printing << Click the link
'Learn about RGB and CMYK colour systems. Find out how Canon inks and paper are designed to work in harmony with printers, providing colour accuracy.' "
‎03-04-2024 09:20 AM
Hello!
So that the Community can help you better, we will need to know more information:
• What is the exact model printer you're using (it's usually on the top or front of the unit)?
• Do you see any error messages?
• Which version of Windows or macOS are you using?
Any other details you'd like to give will only help the Community better understand your issue.
If you're in the United States, and this is an urgent support need, please click HERE to visit your My Canon Account to discover your personalized support options.
If you're outside the USA, please click HERE to find support options in your country.
Thanks, and have a great day!
‎03-04-2024 09:29 AM
I'm printing to my PRO-1000 and PRO-200 models.
There are no error messages displayed.
My MacOS is Ventura 13.6.3.
I'm using the latest version of Professional Print & Layout studio.
‎03-04-2024 04:27 PM
Your printers use expanded CMYK inks, therefore the conversion from RGB is made by the printer driver. You should always load RGB images to the plug-in!
‎03-05-2024 07:06 AM
I understand that the printers use expanded CMYK - that is why designers create the files from scratch in CMYK. There should be no need to convert from RGB to CMYK since the files are in CMYK from the outset.
To be clear - I'm not converting the files to CMYK before loading them in to the plugin - they only exist in CMYK. It seems bizarre if I need to convert them to RGB just so that the printer can convert them back to CMYK.
Also - I'd like to understand if this is something that isn't supported by the application then why isn't it mentioned in the documentation or it should give me an error message when trying to load in a CMYK file rather than silently ignoring it.
‎03-05-2024 07:20 AM
Print Studio PRO can print from CMYK. Give it a try!
‎03-05-2024 08:34 AM
My understanding is that Print Studio Pro only works as a plugin for Photoshop (and other Adobe products).
I can already print from Photoshop as it handles CMYK files - my goal was to use Professional Print & Layout as an alternative to printing from Photoshop to avoid having to buy an Adobe license for each machine I want to print from.
‎03-05-2024 10:45 AM
@phy9pas wrote:My understanding is that Print Studio Pro only works as a plugin for Photoshop (and other Adobe products).
PP&L can be used as a stand-alone product as well as a plugin to LrC and Ps.
‎03-06-2024 02:10 PM
I have exactly the same problem. I was trying to print a TIFF that was encoded using CMYK and the application refused to load it. Converting the file to RGB in another application and trying again fixed the problem.
Seems like a bug to me - if the application doesn't support CMYK files it should really give an error when loading it instead of just pretending like nothing happened.
Maybe when this is fixed we can also have PNG support? That would be nice.
‎03-06-2024 02:15 PM
For completeness, this is on:
Windows 11 Home Version 10.0.22631 Build 22631
Canon PRO-200
Professional Print & Layout v 1.3.8
