Unable to print CMYK files from Professional Print & Layout
phy9pas
I'm trying to use the Canon Professional Print & Layout software to print from my Mac.
It seems like I'm unable to load CMYK files in to the application to print. When I select the file, nothing happens and the file is ignored.
I've tried this with both TIFFs and JPGs - they load up alright when in RGB colourspace but fail if they are CMYK.
I don't want to have to transform all the files to RGB first as this may affect the colours from the original artwork.
Does anybody know if this is a bug or expected behaviour - I can't see this restriction listed anywhere in the documentation. Is there any workaround?
phy9pas
I've just had a response from Canon support confirming that this is the expected behaviour for this software - you cannot print CMYK files to your CMYK Canon printer using Canon software. Mindblowing.
"In response to your enquiry regarding the Professional Print & Layout, I am attaching below the link with of the software's manual with the general notes.
Professional Print & Layout Guide
General Notes (Professional Print & Layout) << Click the link
When starting from supported application
  • One color (8 bits or 16 bits) per pixel RGB data formats supported by the application
Therefore, as you correctly mentioned, this software does not support CMYK files and unfortunately I could not find a workaround.
Lastly, I am attaching below the link of an article with information regarding the RGB and CMYK colour systems.
RGB, CMYK and photo printing << Click the link
'Learn about RGB and CMYK colour systems. Find out how Canon inks and paper are designed to work in harmony with printers, providing colour accuracy.' "
12 REPLIES 12
For completeness, this is on:
Windows 11 Home Version 10.0.22631 Build 22631
Canon PRO-200
Professional Print & Layout v 1.3.8
100% agree! Seems like such an obvious oversight for a "professional" printing product!
phy9pas
