03-04-2024 07:56 AM
I'm trying to use the Canon Professional Print & Layout software to print from my Mac.
It seems like I'm unable to load CMYK files in to the application to print. When I select the file, nothing happens and the file is ignored.
I've tried this with both TIFFs and JPGs - they load up alright when in RGB colourspace but fail if they are CMYK.
I don't want to have to transform all the files to RGB first as this may affect the colours from the original artwork.
Does anybody know if this is a bug or expected behaviour - I can't see this restriction listed anywhere in the documentation. Is there any workaround?
03-07-2024 05:09 AM
Thanks, but the whole thread of this problem is that PP&L can't handle CMYK files.
Somebody suggested PSP as an alternative, but this doesn't solve the problem either since it requires Photoshop.
03-07-2024 05:11 AM
100% agree! Seems like such an obvious oversight for a "professional" printing product!
03-12-2024 05:58 AM
I've just had a response from Canon support confirming that this is the expected behaviour for this software - you cannot print CMYK files to your CMYK Canon printer using Canon software. Mindblowing.
"In response to your enquiry regarding the Professional Print & Layout, I am attaching below the link with of the software's manual with the general notes.
Professional Print & Layout Guide
General Notes (Professional Print & Layout) << Click the link
When starting from supported application
Therefore, as you correctly mentioned, this software does not support CMYK files and unfortunately I could not find a workaround.
Lastly, I am attaching below the link of an article with information regarding the RGB and CMYK colour systems.
RGB, CMYK and photo printing << Click the link
'Learn about RGB and CMYK colour systems. Find out how Canon inks and paper are designed to work in harmony with printers, providing colour accuracy.' "
