01-19-2022 02:41 PM
I have had an issue with saving print settings in PSP through many iterations of Photoshop and it is driving me crazy. I am on a mid-2015 MacBook Pro running Big Sur 11.3.1. I am using Photoshop 2022 v. 23.1.0, with Print Studio Pro v. 2.2.5. PSP is working just fine. My issue is that I do not understand how to save settings. Saving/Registering has never worked for me. I print a lot of greeting cards. I set up everything the way I want it and then save/register it and name it. When I come back into the program and click my saved setting nothing happens. I have to start all over. I finally wrote everything down the way I want it but I have to re-enter it every time. And, it keeps asking to register. I click on apply after a name of one of my saved settings and it asks me to register. I note that there are two spots for saved setting (I think). The box at the top says "My Settings." Under Layout there is a field for registered Layouts. I set it up in both but it is the Layout that is causing me the problems. It looks like the Print Setting Tab and Color Setting Tabs are holding. I cannot figure out how to save the Layout Tab. Should it be saving all my settings?
It is fine if I am doing the same thing over and over, but if I have another print job between one greeting card and the next one I can't get back to the saved setting. They continue to take on the profile of the print job in-between. I expect this whole process should work like a preset only it doesn't. Any help would be much appreciated.
01-19-2022 02:44 PM
I forgot to mention my printer is a Canon Pro-10.
01-19-2022 04:39 PM
I have similar configuration to you, except MacBook Air and Monterey.
The saving works for me.
Do you cycle the My Settings display by clicking on the dropdown arrow. I need to do that to get the saved setting to display.
01-19-2022 04:41 PM
I have Pro-100.
01-19-2022 05:07 PM
No. Mine is always expanded. I have attached a screenshot. Am I supposed to hit the apply button? When I do that it when it tells me to register. And, I have done that a zillion times. On the Layout tab I need the Position-Top to be -.125. I have to offset the image on the card to get it to center. It will not save with the settings.
01-19-2022 05:28 PM
You do need to select Apply.
I will try later with the offset you described.
01-19-2022 06:16 PM
Why when You hit apply does it say register to the right. Your screen shot shows it with “test” which is highlighted in orange now.
01-19-2022 06:59 PM
Try this:
1. when you adjust the margins the way you want you should see the name in Registered Layouts change to Custom.
2. select the "+" icon just below the box and give it a name that you want.
3. up in My Settings select Register and give it a name.
That layout gets saved in that dropdown. It even generates a little icon that looks like the layout.
Image to follow.
01-19-2022 07:04 PM
01-19-2022 07:06 PM
That does not work for me. Once I move away and click on another saved setting that setting is gone. I saved it as "offset," navigated to another setting in My Settings (my card setting without the offset), and although "offset" was in the dropdown box it defaulted back to "0."
