10-07-2024
12:24 AM
11:24 PM
Mike
Running Selphy on Android 14. Since the recent update I've been unable to access Google Photos (service previously connected).
I get this error for both wifi and cellular data:
Failed to acquire Web Service information. Check your Internet connection.
11-15-2024 05:55 PM
Hi Patrick. I did that. It did not resolve it.
01-25-2025 08:37 PM
I am surprised there has been no movement on supporting these issues.
As noted by Natalie this seems to be an issue with v4 of the Selphy app. In order to 'fix' this I had to download an apk file of version 3 from another website.
02-08-2025 06:41 AM
Maybe this helps. Android version 15, Selphy CP910. I was having similar problems with the Selphy photo layout. All I have now is the Canon Print Service app and the Canon Print app. With that installed, open Google Photos and choose a picture, click on share and choose the Canon Print app.
02-08-2025 08:02 AM
Milan9, it would be helpful if you could specify exactly which apps you're referring to.
From what I understand your advice is to bypass the Selphy print app completely?
02-08-2025 09:36 AM
Yes, I use two officials apps by Canon called Canon PRINT and Canon Print Service. I print directly from Google Photos as described and it works fine.
07-11-2025 01:56 PM
I have this same issue on multiple devices, IPhone and Samsung Tablet. I tried these procedures above and it does not work. The Google Photo icon does not appear. it only changes to the Image Cannon Icon and if you click that it displays and Authentication Error. We liked using this app because of the Collage feature, and being able to access shared folder in Google Photo. Everything worked until the app updated and now we can't connect to any Web Service on any device. It there going to be an App update to fix the bugs?
