04-12-2023 03:28 PM
An anomaly, it seems. After many months of not being able to use PSP with Ventura, I was able to make it work on one computer but not another with similar operating system. The change came after I found that Canon has upgraded to Print Studio Pro 2.2.6. The early version 2.2.5 did not work with the PSP and Ventura. Of course, I still cannot understand why the printing software works on an M1 laptop but not on the iMac; PSP does not show under Automation Tools on the desktop. Would like to know why that's happening. Anyone have a similar issue? Thanks.
04-16-2023 07:04 PM
I found a solution. I made sure that the Print Studio Pro folders appear in the Plug-Ins file and in the PSElements file. I copied the file from the Elements area and put the copy into the Plug-Ins area. That enabled me to use PSP.
04-14-2023 01:35 PM
You may need to open Ps using Rosetta..... it works
04-14-2023 03:58 PM
Eduardo,
I thought that Rosetta would open by itself when it was needed. How to I open Rosetta? Thanks.
04-15-2023 05:04 AM
Go to Applications folder / Adobe Photoshop. Command + i on the app / check the box
04-16-2023 03:09 PM
Rosetta feature not available with Elements.
04-16-2023 07:04 PM
04-28-2023 01:10 PM
Yes it does but it greyed the Print and Layout plugin so no switching between the two as of yet. This was with Ventura 13.3.1 running on a M2 Pro chip, 24.4.1 Photoshop release.
