Print Studio Pro error workaround when soft proof is selected on Mac Ventura
eknovack
Found a work around for my error on my M1 Mac Mini running MacOS 13 Ventura.
If I deselect soft proofing PSP runs just fine. This seems like a simple software fix Canon should address.
In any case the work around is:
I have this exact same issue on my M1 Mac Mini with Lightroom CC and print Studio Pro V: 2.2.5.
It exits out with that error message box when I have soft proofing selected. I was able to work arounf this by disabling soft proofing in the xml configuration files:
1- UserSetting_Custom.xml - open this file with textEdit
/Users/(UserName)/Library/Application Support/Print Studio Pro/V2/UserData/Favorites/UserSetting_Custom.xml
Change this key to false
</dict>
<key>USEPROOFMODE</key>
<false/>
2- Config_NormalMode.plist
Edit this file with TextEdit
/Users/(UserName)/Library/ApplicationSupport/Print Studio Pro/V2
Search for proof and change this key to false:
<dict>
<key>DataType</key>
<integer>4</integer>
<key>DataValue</key>
<false/>
</dict>
1 REPLY 1
Johan11
Unfortunately this is - as stated- a work around. Soft proofing is an important aspect when printing, so hopefully Canon can implement a quick fix. The workaround disables soft proofing.
