02-02-2013 04:19 PM
The WiFi (WLAN) set-up works good all day after it starts. But overnight when the printer is inactive it looses it. When trying to print first thing in the morning I have to re-configure it using the "Standard Setup" method which involves typing in my WiFi password (a long and cumbersome process). This machine is new (only 3 days old) and maybe this problem will eventually go away, but it hasn't for the last two mornings. Anybody have this problem? If so, how to fix? Thanks.
04-22-2015 11:24 AM
04-25-2015 09:22 AM
05-21-2015 11:25 AM
07-05-2015 11:52 PM
Did you try the "Easy Setup"?
Theere may be some defaults n there that are not obvious. Mine seems to go offline sometimes and I have to do that whole annoying process with my LAN password and all. Just did it the second time in a month, then added a new pronter to my Mac -- now it works (fingers crossed) -- have not done the PC yet -- tomorrow...
07-05-2015 11:56 PM
07-05-2015 11:58 PM
09-23-2015 11:02 PM
The channel part of this solution worked for me, but I just want to add that my router channel was set to "automatic". When I set it to a specific channel, the same channel that the printer was reporting as its channel, I was able to connect and print without a problem. There was also a checkbox that said to keep the setting during power cycles, and I checked that.
02-17-2016 12:08 AM
06-04-2016 05:54 PM
I have an MB2320 and struggled for several hours to get my network to recognize the printer. The standard driver load steps attempt to connect the printer which failed. I went ahead and loaded the second set of drivers anyway and suddenly the printer was recognized. Try loading all drivers, regardless of the apparent need to connect to the network to be successful.
06-21-2016 11:02 AM
How do you know what signal strength your modem is? I've looked on it, and I don't see any reference to a G or N signal.
