PRO100 WiFi setup problem
MOX
My PRO100 no longer connects to Network no matter what I do. New provider, T-Mobile Gateway/router has no WPS button to push . I have a damaged LAN USB port that has broken socket.
Has anyone replaced the LAN USB cable socket on their Canon PRO-100  located right side rear corner of printer?  Does Canon have them for purchase or is a off the shelf usable?
 Thanks in advance for any help , Mox
2 REPLIES 2
Patrick
Hi MOX,
Please use the Canon PRINT app to connect your PRO-100 to your Wi-Fi.  Please note, if after following these steps you are unable to connect, the issue may be with the security on your TMobile device.  TMobile routers by default have WPA3 security enabled by default. The PRO100 is not compatible with WPA3.  Please contact TMobile support and have them disable WPA3 and enable WPA2. Once WPA2 is enabled, you will be able to connect.  Once your PRO-100 is connected, WPA3 can be enabled again.
To enable cableless setup on your printer, please perform the following:
1.  Please turn your PRO-100 on.
2.  Please press and hold the Wi-Fi button on your PIXMA PRO-100 until the power lamp flashes 2 times, then let it go.
The Wi-Fi light should be blinking on your printer.
Please follow the steps in the article below to complete the connection:
https://support.usa.canon.com/kb/s/article/ART162563
jrhoffman75
Some routers have a software WPS “ button”. Check the manual for the router.
