08-22-2022
11:42 AM
09:22 AM
Hello everyone. I am facing the following problem: While for a long time I was using
Canon Inkjet Cloud Printing Center without any problem to send documents for printing through the dropbox app, suddenly it won't let me sign in to this app. In particular, when I enter my dropbox account credentials, it gives me the message that they are incorrect. I emphasize that the credentials are NOT wrong, I carefully enter them one by one. I also log into my dropbox account normally if I open a new tab in the browser and enter the same credentials. Also to mention that other applications such as onedrive work normally in Canon Inkjet Cloud Printing Center. Does anyone have the same problem? I am attaching screenshots. Thank you for your help!
scn 1
scn 2
scn 3
09-11-2022 11:23 AM
I don't know what Canon has done to fix the problem. On testing, I now see that the app works fine as it did before the problem. Not working for you?
09-11-2022 12:53 PM
on my side all cloud services except google drive are gone.
very disappointed
09-11-2022 02:17 PM
The fact that the applications do not appear does not mean that they are not working. Select the config button and turn on the applications you need. Then test to see if they work. However, for me the Dropbox application that had the problem, now works fine as before.
09-11-2022 03:04 PM
Unfortunately, there are only 2 apps available in the full app store as you can see here
Last week I had dozens available...
09-12-2022 09:33 AM
I guess this is a different type of problem. I don't know, but I have all the available applications that existed before.
09-12-2022 09:40 AM
By all means please share the solution!!
