PIXMA TS3522 wireless installation on MacBook Air
lmiller
 am beyond frustrated with this.  I have MacBook Air Catalina OS 10.16.7.  No matter how many times I try, I cannot get this printer to connect wirelessly.  It will connect via a USB.   Obviously, I need help
7 REPLIES 7
lmiller
I am beyond frustrated with this.  I have MacBook Air Catalina OS 10.16.7.  No matter how many times I try, I cannot get this printer to connect wirelessly.  It will connect via a USB.   How can something so simple be so difficult?
Hi lmiller,
To connect your PIXMA TS3522 to your Wi-Fi, please follow the steps in one of the links below:
How to Connect TS3520/TS3522 to Wi-Fi using an Android phone or tablet
How to Connect TS3520/TS3522 to Wi-Fi using an iPhone/iPad
Once your PIXMA TS3522 is connected to your Wi-Fi, you will be able to add it to your MacBook and be able to print and scan wirelessly.
Patrick
Hi lmiller,
Didn't work.  I can actually see it on the network
lmiller
still not working
nohl
So I've seen this on other wifi printers. It's usually a network that is a higher frequency than the printer's Wi-Fi antenna. I had to set up a 2.4 GHz band network for the printer. Once I linked it to that. Things worked like a breeze.
Guy66
I have the same problem, over a year later. Like you, I did what Patrick suggested to no avail. And again. And again. Did you ever get your issues resolved?
